产品名称: Pentium Celeron 計算機系統
型  号: DT-B1100
Specification
Hardware
CPU
Intel Celeron M/ Pentium M Processor
Chipset
North Bridge: Intel 852GM
South Bridge: ICH4(82801DB)
Memory
Support for up to 1GB of DDR 266/200
1x200pin DDR SO-DIMM Socket
Bios
Award system BIOS
4MB Flash ROM
Support " Power On" after power failure
Support " Wake on LAN"
Display
Internal Graphics (ICH4)
Max 32MB Shared Memory
1x VGA connector
1 x DVI connector (Option)
Support Dural Display (VGA+DVI)
Audio
AC97 2.0 CODEC compatible
1 x Mic-in, 1 x Line-in, 1 x Line-out
Ethernet
RTL 8100C (10/100 Mbps)
1 x RJ-45 connector
Support Second Ethernet ( Option)
I/O Interface
Compact Flash connector: 1 x Type-II (Primary)
IDE connector: 1 x 44 pin Ultra ATA 33/66/100 (Secondary)
PS/2 Port: 1 x Keyboard, 1 x Mouse
USB 2.0 Port: 2 x Front, 4 x Back
Parallel Port: 1 x D-Sub 25pin connector ( SPP/ EPP/ ECP )
Serial Port: 2 x 1L D-Sub 9pin connector ( RS232)
                      Support third and forth Serial port ( Option )
Expansion Slot: 1 x Min PCI ( Option )
Power
DC 12V / 5A, 60W External Power Adapter
Mechanical and Environment
Dimensions
250mm ( L ) X 195mm ( W ) X 50mm ( H )
Housing
Aluminum Case
Temperature
Operating: 0 C - 40 C
Storage: -20 C - 80 C
Relative Humidity
0% - 90 %
Odering Information:
CPU
Intel Celeron M 600MHz 512K Cache (BGA, Fanless)
Intel Celeron M 1GHz 0 Cache (BGA, Fanless)
Intel Celeron M 1.3GHz 512K Cache (PGA, Fan)
Intel Celeron M 1.5GHz 1M Cache (PGA, Fan)
Intel Pentium M 1.6GHz 1M Cache (PGA, Fan)
Intel Pentium M 1.8GHz 2M Cache (PGA, Fan)
Intel Pentium M 2.0GHz 2M Cache( PGA, Fan)
Option:
Metal Mounting Kit (VESA Standard)
Internal Wireless Network Card (Option)
关 键 词: Pentium Celeron
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
