CPU
AMD Geode LX series Processor
Chipset
AMD Geode CS5536 (support USB2.0)
Memory
Support for up to 512MB of DDR 400 / 333 / 266
1 x 200pin SO-DDR DIMM Socket
Bios
Award system BIOS
4MB Flash ROM
Support ¡° Power on¡± after power failure
Support ¡° Wake on LAN¡±
Display
Internal Graphics (AMD Geode LX Series)
Max 256MB Shared Memory
1 x VGA connector
Audio
AC97 2.0 CODCE compatible
1 x Mic-in, 1 x Line-in, 1 x Line-out
Ethernet
RTL 8100C (10/100 Mbps)
1 x RJ-45 connector
I/O Interface
Compact Flash connector: 1 x Type-II (Primary)
IDE connector: 1 x 44pin Ultra ATA 33 / 66 / 100 (Secondary)
PS/2 Port: 1 x Keyboard, 1 x Mouse
USB 2.0: 2 x Front, 2 x Back
Serial Port: 1 x 1L D-Sub 9pin connector (RS232)
Expansion Slot: 1 x Mini PCI (Option)
Power
DC 12V/ 2A, 24W External Power Adapter
Mechanical and Environment
Dimensions
190mm (L) x 150mm (W) x 35mm (H)
Housing
Metal Case
Temperature
Operating: 0 C ¨C 40 C
Storage: -20 C ¨C 80 C
Relative Humidity
0% - 90%
Ordering Information:
CPU
AMD Geode LX700 433MHz (BGA, Fanless)
AMD Geode LX800 500MHz (BGA, Fanless)
AMD Geode LX900 600MHz (BGA,Fanless)
Option
Metal Mounting Kit (VESA Standard)
Internal Wireless Network Card (Option)
