YJTW ϵÁÐÄÍËá¡¢Ä͸ßÎÂѹÁ¦±í
YJTW Series Acid Resistant & High Temperature Resistant Pressure Meter
¼ò½é
±¾ÒDZí¹ã·ºÓ¦ÓÃÓÚʯÓÍ¡¢»¯¹¤¡¢»¯ÏË¡¢Ò±½ð¡¢µçÕ¾µÈ¹¤Òµ²¿ÃÅÖжÔÄÍËá¡¢Ä͸ßÎÂÓнϸßÒªÇóµÄ¹¤ÒÕÁ÷³ÌÖвâÁ¿¸÷ÖÐÁ÷Ìå½éÖʵÄѹÁ¦¡£
ÄÍËáѹÁ¦±íµÄÁã¼þÈ«²¿²ÉÓò»Ðâ¸Ö²ÄÁÏÖÆ³É£¬¾ßÓнÏÇ¿µÄÄ͸¯Ê´ÐÔÄÜ£¬ÊÊÓÃÓÚ¼ì²â¸¯Ê´ÐÔ½ÏÇ¿½éÖʵÄѹÁ¦ºÍÔÚÍⲿ¸¯Ê´»·¾³ÖÐʹÓá£
Ä͸ßÎÂѹÁ¦±íµÄÁã¼þÈ«²¿²ÉÓò»Ðâ¸Ö²ÄÁÏÖÆ³É£¬µ¼Ñ¹ÏµÍ³²ÉÓú¸½Ó¹¤ÒÕ£¬¾ßÓÐÓÅÁ¼µÄÄ͸¯Ê´ÐÔÄÜ¡£ÊÊÓÃÓÚ¶Ô¸¯Ê´ÐÔ½ÏÇ¿µÄ½éÖʺÍÎýÇ¥º¸¹¤ÒÕ²»Ò˲ÉÓõĸßνéÖÊ»òζȽϸ߻·¾³ÖеÄѹÁ¦¼ì²â¡£
Brief introduction:
This sort of meter is used to measure pressure of various liquid mediums, which are widely used in technique flows of industry departments, such as oil industry, chemical industry, chemical fiber, metallurgy, electricity station, etc, which require higher acid-resistant performance.
Parts of acid resistant pressure meter are all made of stainless steel material, so the meters acid-resistant performance is much better and can be used to measure pressure of medium with powerful corrosion.
Parts of high temperature resistant pressure meter are all made of stainless steel material, and welding technique is adopted in its pressure leading system, so the meters corrosion resistant performance is good. This sort of meters can be used to measure pressure of following mediums: medium with strong corrosion, high temperature medium that is not suitable for braze welding technique, or medium with high temperature.
Ö÷Òª¼¼Êõ²ÎÊý Principal technical parameters
ÐͺÅ
Model
¾«È·¶È
Accuracy
ʹÓû·¾³Ìõ¼þ
Condition of
applicable
environment
ζÈÓ°Ïì
Temperature influence
±ê¶È·¶Î§
Measuring ranges£¨MPa£©
YJTW-100
1.6¡¢2.5
-40¡«70¡æ£¬
-40¡«+200¡æ
£¨Ä͸ßΣ©,
Ïà¶Ôʪ¶È²»´óÓÚ85%
(High temperature
resistants)Relative
humidity: ≤85%
ʹÓÃζÈÈçÆ«Àë20±5¡æ
Æäζȸ½¼ÓÎó
²î²»´óÓÚ0.4%/10¡æ
with temperature
departure of 20±5¡æ
the additional errorshall
be less than 0.4%/10¡æ.
0¡«0.6;0¡«1;0¡«1.6;
0¡«2.5;0¡«4;0¡«6;
0¡«10;0¡«25;0¡«40;0¡«60
YJTW-150
0¡«0.6;0¡«1;0¡«1.6;
0¡«2.5;0¡«4;0¡«6;
±ê¼ÇʾÀý£ºYTS-150
ÄÍËáѹÁ¦±í£¬¹«³ÆÖ±¾¶150mm¡£
Marking instance£ºYTS-150 Production computer coding£º1400060302
Acid resistant pressure meter, nominal diameter is 150mm. For detail production computer coding information
