产品名称: AMD LX800 工業主板
型  号: DT-M2100
Specifications
CPU
. AMD Geode LX700 433MHz
. AMD Geode LX800 500MHz
. AMD Geode LX900 600MHz
System Memory
. 1 x 200-pin SO-DIMM socket for DDR266/333/400 SDRAM up to 2GB
Chipset
. AMD Geode CS5536 (USB2.0)
BIOS
. Award system BIOS (Plug & Play)
. Supports “Power on” after power failure
. Supports Wake on LAN
. 4MB Flash ROM
On-board LAN
. 1 x RJ-45 Connector
Audio
. AC97 2.0 CODEC Compatible
. MIC-in, Line-in, Line-out
Display
. 1 x DB15 VGA Connector
. Supports 18 or 24-bit LVDS (option)
I/O Interface
. Serial Port: 1 x D-SUB 9-pin Connector for RS232
. Universal Serial Bus: Supports 4 x USB2.0 Connectors (front x 2, rear x 2)
. Parallel Port (M/B only): 1 x D-SUB 25-pin Connector to support SPP / EPP / ECP mode
. PS/2: 2 x 1L Mini-Din Connector for Keyboard and Mouse
. On-board One Compact Flash Socket (Type-II socket)
. IDE Interface: One 2 x 22 (2.0mm) Box Header
On-board RTC
. Internal RTC supporting by CS5536
Storage
. 2.5” HDD: One 44-pin Connector (secondary)
Expansion Slot
. On-board One PCI Slot (M/B only) or One Mini PCI Socket
. On-board One RJ-11 Connector for Mini PCI Modem Card
System Power
. DC +5V External Power Adapter
Environment
. Board Level Operating Temperature: 0℃~60℃
. System Level Operating Temperature: 0℃~40℃
. Storage Temperature: -20℃~80℃
. Relative Humidity: 5%~90% @ 40℃
Dimensions
. 180 mm (L) x 140 mm (W)
Ordering Information
DT-M2100
. Low Power Embedded Board with AMD Geode LX700 433MHz
. Low Power Embedded Board with AMD Geode LX800 500MHz
. Low Power Embedded Board with AMD Geode LX900 600MHz
Option
. Metal Mounting Kit (VESA Standard)
. Internal Wireless Network Card
关 键 词: LX800 AMD
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
