产品名称: AMD 計算機系統
型  号: DT-B2100
CPU
AMD Geode LX series Processor
Chipset
AMD Geode CS5536 (support USB2.0)
Memory
Support for up to 512MB of DDR 400 / 333 / 266
1 x 200pin SO-DDR DIMM Socket
Bios
Award system BIOS
4MB Flash ROM
Support “ Power on” after power failure
Support “ Wake on LAN”
Display
Internal Graphics (AMD Geode LX Series)
Max 256MB Shared Memory
1 x VGA connector
Audio
AC97 2.0 CODCE compatible
1 x Mic-in, 1 x Line-in, 1 x Line-out
Ethernet
RTL 8100C (10/100 Mbps)
1 x RJ-45 connector
I/O Interface
Compact Flash connector: 1 x Type-II (Primary)
IDE connector: 1 x 44pin Ultra ATA 33 / 66 / 100 (Secondary)
PS/2 Port: 1 x Keyboard, 1 x Mouse
USB 2.0: 2 x Front, 2 x Back
Serial Port: 1 x 1L D-Sub 9pin connector (RS232)
Expansion Slot: 1 x Mini PCI (Option)
Power
DC 12V/ 2A, 24W External Power Adapter
Mechanical and Environment
Dimensions
190mm (L) x 150mm (W) x 35mm (H)
Housing
Metal Case
Temperature
Operating: 0 C – 40 C
Storage: -20 C – 80 C
Relative Humidity
0% - 90%
Ordering Information:
CPU
AMD Geode LX700 433MHz (BGA, Fanless)
AMD Geode LX800 500MHz (BGA, Fanless)
AMD Geode LX900 600MHz (BGA,Fanless)
Option
Metal Mounting Kit (VESA Standard)
Internal Wireless Network Card (Option)
关 键 词: AMD Geode LX800
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
