产品名称: Core 2 Duo 雙核心工控機
型  号: DT-B1105S
Specification
Hardware
CPU
  • Intel® Core 2 Duo/ Core Duo/ Core Solo mobile Processor
  • FSB: 533/800 MHz
Chipset
  • North Bridge: Intel 945GME
  • South Bridge: ICH7M
Memory
  • 2 x 240pin DIMM Socket Support Dual Channel DDR2 533/667 SDRAM up to 4GB
BIOS
  • Award 4MB Flash BIOS
Display
  • Intel 945GME GMCH Integrated Graphic Media Accelerator 950, supports 224MB video memory
  • Resolution: 2048*1536 @32bpp (@60Hz)
  • Dual Display: CRT + LVDS
  • LVDS: 18/24-bit Dual-channel LVDS
Audio
  • Chipset: Intel 82801GM ICH7M
  • Codec: Realtek ALC888 5.1 + 2 Ch Audio Codec supports 2 independent audio streams
  • 1 x Mic-in,1 x Line-in,1 x Line-out
Ethernet
  • Controller: Marvell 88E8053
  • 2 x Gigabit Ethernet Port
  • Wireless LAN (through Mini-PCI slot, Optional)
I/O Interface
  • SSD: 1 x Type II Compact Flash Connector
  • IDE connector:1 x 40pin IDE Connector
  • SATA: 2 x Serial ATA Connector
  • PS/2 Port :1 x Keyboard, 1 x Mouse
  • USB 2.0 Port:2 x Front, 4 x Rear
  • Serial Port:3 x 1L D-SUB 9pin connector (2 Powered COM)
  • DIO: 8-bit General Purpose I/O for DI & DO
  • Expansion Slot: 1 * PCI, 1 * Mini PCI
Power
  • 125W Internal Power Supply
Watchdog Timer
  • Reset: 1 sec ~ 255 min. and 1 sec or 1 min/step
H/W Status Monitor
  • Monitoring CPU temperature, voltage, and cooling fan Status.
  • Auto throttling control when CPU overheats
Mechanical and Environment
Dimensions
  • 310mm ( L ) X 255mm ( W ) X 100mm ( H )
Housing
  • Metal Case
Temperature
  • Operating:0oC ~ 40oC
  • Storage:- 20oC ~ 80oC
Relative Humidity
  • 0 %~ 90%
Odering Information:
 DT-B1104S
  • Socket 478 Intel Core 2 Duo/ Core Duo with Dual LAN, 6 USB, Mini-PCI x 1, PCI x 1 Expansion
关 键 词:
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
