产品名称: 17 Panel PC 觸控螢幕工控機
型  号: DT-PPC965
The DT-PPC 965 industrial touch panel computer is an all-in-one and compact system designed around a highly integrated Intel® 965GME chipset motherboard computer which is equipped with a 17-inch XGA TFT LCD display.
It provides a smart "All in One" design for tiny space to meet the highly performance requirements for business and industrial applications including Gaming, Automation, POS, Kiosk, Education, Network communication , Work Place and Information Center.
Specification:
Display Type 17" SXGA TFT LCD
Resolution 1280 x 1024 pixels
Luminance / Brightness 300 cd/m2
Color 16.7 M (8 bits/colors)
Pixel Pitch (H/V) 0.297 mm X 0.297 mm
Contrast Ratio 500 : 1 (typ.)
Viewing Angle (H/V) 160゚/ 160゚ (typ.)
Backlight MTBF 50,000 hrs
Touch Screen Type 5 Wire Resistive Touch Screen
System:
CPU: Intel Core 2 Dou/ Duo Core with 65nm process technology
Chipset: 965GME+ICH8
Mini ITX Form Factor: 17 x 17 cm
DDR2 800 SDRAM up to 4GB
Two Gigabit LANs
Compact Flash Socket
Ten USB 2.0
Four Serial Ports
One IDE slot
One PCI
One PCIE x 16
Dimension 430mm(W) x 350mm(H) x 109.2mm(D)
Weight 9.3kg
Environment Storage Temperature: -20゚~60゚C
Operating Temperature: 0゚~50゚C
Relative Humidity: 10%~95% , non-condensing
关 键 词: Panel PC
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
