产品名称: 10.4 寸 Panel PC 觸控螢幕工控機
型  号: DT-PPC800LX
The DT-PPC800LX industrial touch panel computer,  is an all-in-one and compact system designed around a highly integrated AMD® CS5536 chipset embedded computer. Equipped with a 10.4-inch VGA TFT LCD display, an embedded ultra low power consumption AMD® Geode LX800 CPU, a fanless cooling system, it offers a smart design for economic space to meet the highly performance requirements for business and industrial applications including stores / warehouse / home/ school, POS, Kiosk, Network Communication and Information terminal.
Display Type 10.4" VGA TFT LCD
Resolution 640 x 480 pixels
Luminance / Brightness 350 cd/m2
Color 262K (8 bits/colors)
Pixel Pitch (H/V) 0.330 mm X 0.330 mm
Contrast Ratio 300 : 1 (typ.)
Viewing Angle (H/V) 140゚/ 140゚(typ.)
Backlight MTBF 50,000 hrs
Touch Screen Type 5 Wire Resistive Touch Screen with USB Interface
System:
CPU: AMD Geode LX800 500MHz
1 x 200-pin SO-DIMM socket for DDR266/333/400 SDRAM up to 2GB
Chipset
. AMD Geode CS5536 (USB2.0)
On-board LAN
. 1 x RJ-45 Connector
. Supports Wake on LAN
I/O Interface
. Serial Port: 1 x D-SUB 9-pin Connector for RS232
. Universal Serial Bus: Supports 4 x USB2.0 Connectors (front x 2, rear x 2)
. Parallel Port (M/B only): 1 x D-SUB 25-pin Connector to support SPP / EPP / ECP mode
. PS/2: 2 x 1L Mini-Din Connector for Keyboard and Mouse
. On-board One Compact Flash Socket (Type-II socket)
. IDE Interface: One 2 x 22 (2.0mm) Box Header
On-board RTC
. Internal RTC supporting by CS5536
Storage
. 2.5” HDD: One 44-pin Connector (secondary)
Expansion Slot
. On-board One PCI Slot (M/B only) or One Mini PCI Socket
. On-board One RJ-11 Connector for Mini PCI Modem Card
System Power
. DC +5V External Power Adapter
Dimention: 300mm(W) x 69.6mm(D) x 250mm(H)
关 键 词: Panel PC touch
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
