产品名称: Atom 迷你工控機
型  号: DT-B1110S
Specifications
CPU
Intel® N270 Atom™ processor
System Memory
l          1 x 200-pin SO-DIMM Socket Support Dual Channel DDR2 400/533/667 SDRAM up to 1GB
Chipset
Intel® 945GSE + ICH7M
BIOS
l          Award system BIOS
l          Supports “Power on” after power failure
l          Supports Wake on LAN
l          8MB flash ROM
Ethernet
l          Onboard Two Realtek RTL8111C Gigabit LAN
Audio
l          Built-in Intel® High Definition Audio
l          Audio Codec:VIA VT1708A HDA Codec
l          Audio Interface:Mic-in, Line-in, Line-out
Display
l          Intel® Graphics Media Accelerator (GMA) 950,
l          VGA or DVI-I / One Channel LVDS
I/O Interface
l          Chipset:Winbond W83627HG
Serial Port:1 x External D-SUB 9-pin Connectors for COM1(RS232/422/485), 1 x Internal pin header for  COM2(RS232)
          Universal Serial Bus 2.0:6 x External USB Connector
          PS/2:One Mini-Din Connector for Keyboard and Mouse
          Compact Flash:1 x Compact Flash connector
          SATA:2 x SATA II
          GPIO:4 in / 4 out
          SSD:One CompactFlash Type I/II socket
Watchdog Timer
          Reset : Generates system reset; 256 levels
H/W Status Monitor
          Monitoring CPU temperature, and voltage status.
Expansion Slot
          One PC-104+ slot
System Power
          Adaptor (12V/5A)
Environment
          System Level Operating Temperature: 0oC ~40oC
          Storage Temperature: -20oC ~80oC
Dimensions
          166 mm (L) x 122 mm (W)
关 键 词: Atom
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
