CPU
l VIA Eden-V4 400MHz~1.5GHz Processor
l VIA C7 1.0GHz~2.0GHz Processor
System Memory
l 1 x 200-pin SODIMM Socket for DDR2 533 SDRAM up to 1GB
Chipset
l VIA CX700M Chipset
BIOS
l Award system BIOS
l Supports “Power on” after power failure
l Supports Wake on LAN
l 4MB flash ROM
LAN
l On Board One Realtek RTL8110SC Chip to support 10/100/1000Mbps Ethernet
l 1 x RJ-45 connector
Audio
l Audio Codec:VIA VT1708A HDA Codec
l Audio Interface:Mic-in, Line-in, Line-out
Display
l 1 x DVI-I connector (VGA & DVI)
l 1 x 18/24bit LVDS connector
I/O Interface
l 1 x External D-SUB 9-pin Connectors for COM1(RS232), 1 x Internal pin header for COM2(RS232/422/485)
l Universal Serial Bus: Supports 6 x USB2.0 connector (Front x 4, Rear x 2)
l PS/2: One Mini-Din connector for keyboard and mouse
l On-board One compact flash Socket(Type-II socket)
l Serial-ATA Interface: Two SATA connector
Watchdog Timer
l Reset : Generates system reset; 256 levels
H/W Status Monitor
l Monitoring CPU temperature, and voltage status.
On-board RTC
l Internal RTC supporting by CX700M
Expansion Slot
l One PC-104 Slot
System Power
l ATX Power
Environment
l System Level Operating Temperature: 0oC ~40oC
l Storage Temperature: -20oC ~80oC
Dimensions
l 166 x 122 mm
