PoCL/Mini CL 黑白逐行扫描相机I
KP-F500PCL/SCL, KP-F230PCL/SCL, KP-F31PCL/SCL, KP-FB30PCL/SCL
品牌:日立(HITACHI)
主要特点
Mini CL (迷你CameraLink)
采用CameraLink接口,可以实现图像数据的高速传输。同时MiniCameraLink接口的使用,使得相机的外型变得更加小巧。
PoCL (供电型CameraLink)
采用供电型CameraLink接口,可使电源供给、图像数据传送、相机控制通过一条CameraLink连线与图像采集卡相连接,使得构建应用系统更简单。
高清晰度、高帧数:高清晰度与高帧数同时实现。
可以广泛应用于同时需要高清晰度和高帧数传输的领域。
KP-F500PCL/SCL |
5.05 Megapixel |
16 |
frame/second |
KP-F230PCL/SCL |
2.01 Megapixel |
30 |
frame/second |
KP-F200PCL/SCL |
2.01 Megapixel |
15 |
frame/second |
KP-F80PCL/SCL |
0.81 Megapixel |
36 |
frame/second |
KP-F31PCL/SCL |
0.33 Megapixel |
120 |
frame/second |
KP-F39PCL/SCL |
0.33 Megapixel |
91 |
frame/second |
KP-F30PCL/SCL |
0.33 Megapixel |
60 |
frame/second |
KP-FB30PCL/SCL |
0.33 Megapixel |
60 |
frame/second |
技术参数:
品牌:日立(HITACHI)
主要特点
KP-F500PCL/SCL |
5.05 Megapixel |
16 |
frame/second |
KP-F230PCL/SCL |
2.01 Megapixel |
30 |
frame/second |
KP-F200PCL/SCL |
2.01 Megapixel |
15 |
frame/second |
KP-F80PCL/SCL |
0.81 Megapixel |
36 |
frame/second |
KP-F31PCL/SCL |
0.33 Megapixel |
120 |
frame/second |
KP-F39PCL/SCL |
0.33 Megapixel |
91 |
frame/second |
KP-F30PCL/SCL |
0.33 Megapixel |
60 |
frame/second |
KP-FB30PCL/SCL |
0.33 Megapixel |
60 |
frame/second |
技术参数:
Model |
KP-F500PCL
/SCL |
KP-F230PCL
/SCL |
KP-F31PCL
/SCL |
KP-FB30PCL
/SCL |
Imaging device |
2/3-inch interline CCD |
1/1.8-inch interline CCD |
1/3-inch interline CCD |
Total pixels |
2536 (H) x 2068 (V) |
1688 (H) x 1248 (V) |
692 (H) x 504 (V) |
Effective pixels |
2456 (H) x 2058 (V) |
1628 (H) x 1236 (V) |
659 (H) x 494 (V) |
Pixel size |
3.45 µm (H) x 3.45 µm (V) (square lattice) |
4.4 µm (H) x 4.4 µm (V) (square lattice) |
7.4 µm (H) x 7.4 µm (V) (square lattice) |
Sensing area |
8.47 mm (H) x 7.10 mm (V) |
7.16 mm (H) x 5.44 mm (V) |
4.88 mm (H) x 3.66 mm (V) |
Scanning system |
Progressive |
Aspect ratio |
5:4 |
4:3 |
Frame rate |
16 frames per second (full pixel readout) |
30 frames per second (full pixel readout) |
120 frames per second (full pixel readout) |
60 frames per second (full pixel readout) |
54 frames per second (vertical 2 pixel addition) |
219 frames per second (vertical 2 pixel addition) |
Sync system |
Internal |
Lens mount |
C mount (Flange focal distance = 17.526 mm) |
Special mount (Flange focal distance = 8.4 mm) |
Resolution |
Horizontal/Vertical: 2000TV lines |
Horizontal / Vertical: 1200 TV lines |
Horizontal: 500 TV lines / Vertical: 490 TV lines |
Sensitivity |
400 lx, F5.6, 3200 K |
500 lx, F5.6, 3200 K |
550 lx, F4, 3200 K |
750 lx, F5.6, 3200 K |
Minimum illumination |
1.0 lx (F1.4, MAX GAIN, without IR cut filter) |
3.9 lx (F1.4, MAX GAIN) |
8.6 lx (F1.4, MAX GAIN) |
5.9 lx, F1.4, MAX GAIN |
Signal noise to ratio |
48dB |
45dB |
50 dB |
Gamma |
γ = 1 |
Trigger input |
CameraLink (CC1) or DCIN/SYNC connector |
CameraLink (CC1) *When Reset control mode CC1 and CC2 are used |
Partial scan |
Selectable start position and height of picture grabbing in 1H step. |
Power supply voltage |
12 ± 1 VDC |
External dimensions |
44 (W) x 44 (H) x 41 (D) mm (Not including protrusions) |
29 (W) x 29 (W) x 38 (D) mm (Not including protrusions) |
Head: 12 (W) x 12.5 (H) x 47.5 (D) mm |
CCU: 29 (W) x 29 (H) x 38 (D) mm |
Mass |
Approx. 110 g |
Approx. 50 g |
Head: Approx. 18 g |
CCU: Approx. 50g (without cable |
