PoCL/Mini CL Raw数据输出 逐行扫描相机II
KP-FR200PCL/SCL, KP-FR80PCL/SCL, KP-FR39PCL/SCL, KP-FR30PCL/SCL
品牌:日立 (HITACHI)
主要特点
RAW数据输出
RGB图像由RGB原色马赛克滤光片的各个感光区的原始数据直接转换输出得到。使得计算
机取得的图像质量损失最少。
★ RAW数据转换为彩色图像需要有专门软件来完成。
帧快门:可提高移动物体的垂直清晰度。
多级快门:凡具有多级可变快门。(最小1/100,000秒)
帧请求:图像开始时间和曝光时间可由触发信号任意控制。
远程控制:通过CameraLink接口,快门、模式、增益局部扫描、比特位等。
多种相机的控制和调整都可以实现。
局部扫描: 局部扫描功能可取得从开始线到指定幅度间的任意画面。
可实现画面的高帧数传输。
比特位数可选:
12-/10-/8-bit |
KP-FR500PCL/SCL |
10-/8-bit |
KP-FR230PCL/SCL,KP-FR200PCL/SCL,KP-FR80PCL/SCL,KP-FR31PCL/SCL,
KP-FR39PCL.SCL,KP-FR30PCL/SCL,KP-FBR30PCL/SCL |
KP-FRxxxPCL KP-FRxxxSCL
技术参数:
Model |
KP-FR200PCL
/SCL |
KP-FR80PCL
/SCL |
KP-FR39PCL
/SCL |
KP-FR30PCL
/SCL |
Imaging device |
1/1.8-inch interline CCD |
1/3-inch interline CCD |
Effective pixels |
1628 (H) x 1236 (V) |
1034 (H) x 779 (V) |
659 (H) x 494 (V) |
Color filter |
RGB primary color mosaic filter |
Sensing area |
7.16 mm (H) x 5.44 mm (V) |
4.76 mm (H) x 3.57 mm (V) |
4.88 mm (H) x 3.66 mm (V) |
Scanning system |
Progressive |
Aspect ratio |
4:3 |
Frame rate |
15 frames per second (full pixel readout) |
36 frames per second (full pixel readout) |
91 frames per second (full pixel readout) |
60 frames per second (full pixel readout) |
Scanning frequency |
Horizontal: 18.75 kHz, Vertical: 14.97 Hz |
Horizontal: 28.346 kHz, Vertical: 35.79 Hz |
Horizontal: 46.875 kHz, Vertical: 91.73 Hz |
Horizontal: 31.468 kHz, Vertical: 59.94 Hz |
Sync system |
Internal |
Lens mount |
C mount (Flange focal distance =17.526 mm) |
Video output |
Digital output (CameraLink) |
Resolution |
Horizontal / Vertical: 1200 TV lines |
Horizontal / Vertical: Approx. 800 TV lines |
Horizontal: 500 TV lines / Vertical: 490 TV lines |
Sensitivity |
2000 lx, F8, 3200 K |
2000 lx, F4, 3200 K |
2000 lx, F5.6, 3200 K |
Minimum illumination |
5.0 lx (F1.4, MAX GAIN) |
20 lx (F1.4, MAX GAIN) |
10 lx (F1.4, MAX GAIN) |
Signal noise to ratio |
50 dB |
Gamma |
γ = 1 |
Trigger input |
CameraLink (CC1) *When Reset control mode CC1 and CC2 are used |
Partial scan |
Selectable start position and height of picture grabbing in 1H step. |
Power supply voltage |
12 ± 1 VDC |
External dimensions |
29 (W) x 29 (W) x 29 (D) mm (Not including protrusions) |
Mass |
Approx. 50 g |
