产品名称: 启科:PoCL/Mini CL Raw数据输出逐行扫描相机I
型  号: KP-FR500PCL/SCL, KP-RF230PCL/SCL, KP-FR31PCL/SCL, KP-FBR30PCL/SCL
品  牌: 日立HITACHI
PoCL/Mini CL  Raw数据输出 逐行扫描相机I
品牌:日立HITACHI)
主要特点
Mini CL (迷你CameraLink
采用CameraLink接口,可以实现图像数据的高速传输。同时MiniCameraLink接口的使用,使得相机的外型变得更加小巧。
PoCL (供电型CameraLink)
采用供电型CameraLink接口,可使电源供给、图像数据传送、相机控制通过一条CameraLink连线与图像采集卡相连接,使得构建应用系统更简单。
高清晰度、高帧数:高清晰度与高帧数同时实现。
可以广泛应用于同时需要高清晰度和高帧数传输的领域。
KP-FR500PCL/SCL
5.05 Megapixel
16
frame/second
KP-FR230PCL/SCL
2.01 Megapixel
30
frame/second
KP-FR200PCL/SCL
2.01 Megapixel
15
frame/second
KP-FR80PCL/SCL
0.81 Megapixel
36
frame/second
KP-FR31PCL/SCL
0.33 Megapixel
120
frame/second
KP-FR39PCL/SCL
0.33 Megapixel
91
frame/second
KP-FR30PCL/SCL
0.33 Megapixel
60
frame/second
KP-FBR30PCL/SCL
0.33 Megapixel
60
frame/second
技术参数:
Model
KP-FR
500PCL/SCL
KP-FR
230PCL/SCL
KP-FR
31PCL/SCL
KP-FBR
30PCL/SCL
Imaging device
2/3-inch interline CCD
1/1.8-inch interline CCD
1/3-inch interline CCD
Effective pixels
2456 (H) x 2058 (V)
1628 (H) x 1236 (V)
659 (H) x 494 (V)
Color filter
RGB primary color mosaic filter
Sensing area
8.47 mm (H) x 7.10 mm (V)
7.16 mm (H) x 5.44 mm (V)
4.88 mm (H) x 3.66 mm (V)
Scanning system
Progressive
Aspect ratio
 54
 43
Frame rate
16 frames per second (full pixel readout)
30 frames per second (full pixel readout)
120 frames per second (full pixel readout)
60 frames per second (full pixel readout)
Sync system
Internal
Lens mount
C mount (Flange focal distance = 17.526 mm)
Special mount
Video output
Digital output  (CameraLink)
Resolution
Horizontal/Vertical: 2000TV lines
Horizontal / Vertical: 1200 TV lines
Horizontal: 500 TV lines / Vertical: 490 TV lines
Sensitivity
2000 lx, F8, 3200K
2000 lx, F5.6, 3200 K
2000 lx, F4, 3200 K
Minimum illumination
15 lx (F1.4 GAIN MAX)
20 lx (F1.4, MAX GAIN)
35 lx (F1.4, MAX GAIN)
Signal noise to ratio
48dB
45 dB
50 dB
Gamma
γ = 1
Trigger input
CameraLink (CC1) or DCIN/SYNC connector
CameraLink (CC1)  *When Reset control mode CC1 and CC2 are used
Partial scan
Selectable start position and height of picture grabbing in 1H step.
Power supply voltage
12 ± 1 VDC
External dimensions
44 (W) x 44 (H) x 41 (D) mm(Not including mount protrusions)
29 (W) x 29 (W) x 38 (D) mm (Not including protrusions)
Head: 12 (W) x 12.5 (H) x 47.5 (D) mm
CCU: 29 (W) x 29 (H) x 38 (D) mm
Mass
Approx. 110 g
Approx. 50 g
Head: Approx. 18 g
CCU: Approx. 50g (without cable)
关 键 词: PoCL Mini CL Raw数据输出
公司名称: 启科(上海)自动化系统有限公司
联 系 人: 张安琪
电  话: 021-51978078
手  机:
地  址: 上海市浦东新区金港路333号禹州金桥国际大厦一座802室
邮  编: 201206
剔除器
启科推出:像素7400,(TL-7400RCL)
空瓶检瓶机(STW-24VB)
启科推出系列Camera(CM-200MCL/CB-200MCL,CM-140MCL/CB-140MCL)
启科:PoCL/Mini(KP-FR200PCL/SCL, KP-FR80PCL/SCL, KP-FR39PCL/SCL, KP-FR30PCL/SCL)
直线式空瓶检测机
启科推出系列高像素工业相(AM-1600GE/AB-1600GE,AM-1600CL/AB-1600CL,BM-500GE/BB-500GE,BM-500CL/BB-500CL)
PET满瓶检测机
启科:PoCL/Mini(KP-F500PCL/SCL, KP-F230PCL/SCL, KP-F31PCL/SCL, KP-FB30PCL/SCL)
全方位牛奶瓶检测机(KBI-276D)
启科:瓶盖检测机
接插件检测机VTV-90(VTV-9000)
空罐检测机
启科推出:2K像素彩色3(TLC-2098CLS)
吸塑包装检测机
启科推出:像素5150,(TL-5150UCL)
启科:3CCD工业相机(HV-F22F, HV-F31F)
启科:IEEE1394.(KP-F140F, KP-F83F, KP-F32F)
启科:瓶胚检测机
