一、用途及适用范围 INTRODUCTION AND APPLICATIONS T系列热继电器适用于交流50HZ或60HZ,电压至660V,电流至500A的电力线路中。一般用作三相感应电动机的过载与断相保护,常与B系列交流接触器配合组成电磁起动器。本产品是引进德国ABB公司制造技术的产品。 注:T16为手动复位,其他为手动和自动复位。具体见《产品使用说明书》 T series thermal overload relay is mainly suitable for A.C.electric power system with voltage up to 660V,current up to 500A,50-60HZ.It is generally used for the protection of overload and phase-tacking in circuits with three-phasse induce motors and is offen made up electromagnetic starters with B series A.C.contactors. Note:T16 is manually reset aucomatic to the other.AS shown on 《The operating introduction》 二、动作特性:三相负载平衡时的动作时间 MOTION CHARACTERISTIC:THREE-PHASE BALANCE MOTION TIME |
序号 No |
整定电流倍数 Set current cinles |
动作时间 Motion time |
起始条件 Start conidition |
环境温度 Temperature |
1 |
1.05 |
>2h |
冷态 Cold state |
20±5℃
2 |
1.2 |
>2h |
热态 Heat state (接序号1试验后) Following the No 1 test |
3 |
1.5 |
<4min |
4 |
7.2 |
10A |
2S |
≤63A |
冷态 Cold state |
10A |
4S |
>63A |
三、断相动作性能 PHASE-LOSING MOTION CHARACTERISTIC
序号 No |
动作时间 Motion time |
环境温度 Temperature |
任意二相 Arbitrary two phase |
第三相 Three phase |
1 |
1.0 |
0.9 |
冷态 Cold state |
20±5℃ |
2 |
1.15 |
0 |
