VIA Eden-V4(400MHz/500MHz/600MHz/800MHz/1.0GHz/1.2GHz) / C7(1.0/1.3/1.5GHz)
Processor
. VIA VIA Eden-V4/C7 + VIA CX700(M) Chipset
. 1 x 200-pin SODIMM Socket Supports DDR2 533 SDRAM up to 1GB
. Supports DVI Display
. Supports TV OUT Display (Option)
. Supports LVDS Display
. Supports One Channel IDE Interface (Two Devices)
. Compact Flash Socket
Specification:
CPU
. VIA Eden-V4 400MHz
. VIA Eden-V4 500MHz
. VIA Eden-V4 600MHz
. VIA Eden-V4 800MHz
. VIA Eden-V4 1.0GHz
. VIA Eden-V4 1.2GHz
. VIA C7 1.0GHz
. VIA C7 1.3GHz
. VIA C7 1.5GHz
System Memory
. 1 x 200-pin SODIMM Socket for DDR2 533 SDRAM up to 1GB
Chipset
. VIA CX700(M) Chipset
BIOS
. Award system BIOS (Plug & Play)
. Supports “Power on” after power failure
. Supports Wake on LAN
. 4MB flash ROM
On-board LAN
. 2 x RJ-45 connector
Audio
. AC97 2.0 CODEC compatible
. MIC-in, Line-in, Line-out
Display
. 1 x DVI-I connector(VGA & DVI)
. 1 x TV OUT connector(Pin Header)(Option)
. 1 x 18/24bit LVDS connector
I/O Interface
. Serial Port: One D-SUB 9-pin connector for RS232
One 2 x 5 (2.0mm) box header for RS232
Two 2 x 5 (2.0mm) box header for RS232/422/485
. Universal Serial Bus: Supports 6 x USB2.0 connector (Rear x 2, Internal x4)
. Parallel Port: One 2 x 13 (2.0mm) box header to support SPP / EPP / ECP mode
. PS/2: One Mini-Din connector for keyboard and mouse
. On-board One compact flash Socket(Type-II socket)
. IDE Interface: One 2 x 22 (2.0mm) box header
On-board RTC
. Internal RTC supporting by CX700(M)
Storage
. 2.5”HDD: One 44-pin connector (secondary)
. Compact Flash: On-board One compact flash Socket(Primary)
Expansion Slot
. One Mini PCI socket (Option)
System Power
. ATX Power Supply(DC 5V/12V/5VSB)
Environment
. Board Level Operating Temperature: 0℃~60℃
. System Level Operating Temperature: 0℃~40℃
. Storage Temperature: -20℃~80℃
. Relative Humidity: 5~90% @40℃
Dimensions
. 146 x 102 mm
Daughter Boards
l 12V DC-DC Power Board
l Connector Board: 4 x USB / Audio (Mic-In/
Line-In/Spk-Out) / 1 x Power button /
1 x Reset button / 2 x LED indicators
