产品名称: Intel Pentium / Celeron 工業主板
型  号: DT-M1100S
Specifications
CPU
. Intel® Celeron® M 600MHz 512K Cache Processor (BGA Type, Fanless)
. Intel® Celeron® M 1GHz 0 Cache Processor (BGA Type, Fanless)
. Intel® Celeron® M 1.3GHz 512K Cache Processor (FCPGA Type, with Fan)
. Intel® Celeron® M 1.5GHz 1M Cache Processor (FCPGA Type, with Fan)
. Intel® Pentium® M 1.6GHz 1M Cache Processor (FCPGA Type, with Fan)
. Intel® Pentium® M 1.8GHz 2M Cache Processor (FCPGA Type, with Fan)
. Intel® Pentium® M 2.0GHz 2M Cache Processor (FCPGA Type, with Fan)
System Memory
. 1 x 200-pin SO-DIMM socket for DDR200/266 SDRAM up to 1GB
Chipset
. Intel® 852GM + ICH4 (82801DB)
BIOS
. Award system BIOS (Plug & Play)
. Supports "Power on" after power failure
. Supports Wake on LAN
. 4MB Flash ROM
On-board LAN
. 1 x RJ-45 Connector (REL8100C)
Audio
. AC97 2.0 CODEC Compatible
. MIC-in, Line-in, Line-out
Display
. 1 x DB15 VGA Connector
. 1 x 18/24-bit LVDS Connector (supports one channel LVDS LCD)
. Supports Dual Display
I/O Interface
. Serial Port: Four 2 x 2L D-SUB 9-pin Connectors for RS232 (4 x COM)
. Universal Serial Bus: Supports 6 x USB2.0 Connectors (2 x front, 4 x rear)
. Parallel Port: One 2 x 13 x 2.0mm Box Header to support SPP / EPP / ECP mode
. PS/2: One 1 x 2L Mini-Din Connector for Keyboard and Mouse
. On-board One 2 x 17 (2.54mm) Box Header to support FDD Device
. IDE Interface: Two 2 x 22 (2.0mm) Box Header to support Two ATA-33/66/100 IDE Device
On-board RTC
. Internal RTC supporting by ICH4 (82801DB)
Storage
. HDD: Two 44-pin 2 x 22 (2.0mm) Connectors, Ultra ATA 33/66/100
Expansion Slot
. On-board One PCI Slot or Mini PCI Socket
System Power
. 20-pin ATX Power Input Connector
. DC +12V External Power Adapter
Environment
. Board Level Operating Temperature: 0oC~60oC
. System Level Operating Temperature: 0oC~40oC
. Storage Temperature: -20oC~80oC
. Relative Humidity: 0%~90%
Dimensions
. 200 mm (L) x 170 mm (W)
Ordering Information
DT-M3100
. Low Power Embedded Board with Intel® Celeron® M 600MHz
. Low Power Embedded Board with Intel® Celeron® M 1GHz
. Low Power Embedded Board with Intel® Celeron® M 1.3GHz
. Low Power Embedded Board with Intel® Celeron® M 1.5GHz
. Low Power Embedded Board with Intel® Pentium® M 1.6GHz
. Low Power Embedded Board with Intel® Pentium® M 1.8GHz
. Low Power Embedded Board with Intel® Pentium® M 2.0GHz
Option
. Metal Mounting Kit (VESA Standard)
. Internal Wireless Network Card
关 键 词: Pentium Celeron 無風扇
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
