产品名称: ISA总线定时/计数卡
型  号: IDAQ-5754
价  格:
产品特性
8-CH timers/counters
2-CH cascaded 32-bit timer with 1 MHz base clock
On-board multiple base clocks ranging from 100 kHz to 2 MHz
External gate control and clock inputs for each counter
Inverted gate signals for 4-CH synchronized frequency measurement
Multiple interrupt sources from counter outputs, timer outputs and external interrupt inputs
产品规格
iDAQ-5754 is a general-purpose timer/counter and digital I/O card. It is a compact-size add-on card for IBM AT compatible PC in control, monitoring and sensing applications. iDAQ-5754 has four 8254 chips which results in eight general-purpose 16-bit counters and two 32-bit timer. The counters can be set as independent counters or cascaded counters. The gate control of every counter comes from either external source or internal cascaded counters. The clock source comes from either internal timebase or external inputs, which can be selected by jumper setting. iDAQ-5754 delivers cost-effective and reliable digital output capabilities and are ideal for a broad variety of applications.
关 键 词: ISA总线定时/计数 IDAQ-5754
公司名称: 深圳市艾卡电子技术有限公司
联 系 人: 黄一克
电  话: 0755-86652895
手  机: 13410299901
地  址: 深圳市南山区西丽镇珠光创新科技园2栋402
邮  编: 518055
PC/104总线CAN通(ICOM-3802)
SMT用32路隔离数字量(IDAQ-5730)
PC/104 总线4串口(ICOM-3304)
可编程定时/计数卡(IDAQ-5836)
PCI总线6串口RS-2(ICOM-6306)
USB转RS-422/4(ICOM-8452p)
PCI总线2串口RS48(ICOM-6502(P))
PC/104总线32通道(IDAQ-3730)
超低价PCI总线CAN通(ICOM-6802)
定时/计数卡(IDAQ-5754)
PCI 转8串口232卡(ICOM-6308)
增强型ISA总线多功能数(IDAQ-5812)
PC/104总线I/O卡(IDAQ-3725)
PCI总线2串口RS-2(ICOM-6302)
研华工控主板6003VE(PCA-6003VE)
超低价GPIB 高性能P(PCI-1670)
16位高分辨率DAS卡(PCL-816)
双通道光电隔离模拟量输出(IDAQ-5728)
研华嵌入式主板(PCM-9479)
